Posted: 2020-07-02 08:24 AM . Last Modified: 2024-04-10 01:31 AM
Hi Team.
After i added a server in the rack, and then save the configuration at opeartion tool
I checked total U space qty thru portal web view.
But The total qty was not changed
So How can i synchronize it , that mean "data synchronization" PORTAL AND Operation View
(CID:89555407)
The StruxureWare Portal is presenting capacity history data (KPIs) coming from DCO. These data points are recorded one time a day (by default). Therefore you might experience a delay in data synchronization between DCO and Portal depending on what time of the day the capacity history data is collected.
More info regarding capacity history data (KPIs): Capacity History (KPIs) over time.
(CID:89555411)
(CID:89555411)
Thanks Soren How can i do update the data by manualy ? Do you know the way to manual update the total capacity ?
(CID:89555431)
Hi, there are no way of manually updating the data. It will be done automatically based on data from the latest 24 hours. You could trigger a "record now" in the capacity history configuration page. This will schedule and execute the calculation right away and thereby give an extra KPI data point. The record now should be used with some caution (especially on very large solutions) since data collection will take compute power from the server while executing.
(CID:89555457)
Posted: 2020-07-02 08:24 AM . Last Modified: 2023-10-31 11:41 PM
