Posted: 2020-07-02 08:24 AM . Last Modified: 2024-04-10 01:31 AM
(CID:89555474)
Posted: 2020-07-02 08:24 AM . Last Modified: 2024-04-10 01:30 AM
Dear Craig,
configuring a new PDU is best done with a supplied serial COM cable and login with putty.
commands can be found in the documentation, or type help in as command.
After configuration, you can just connect the PDU with a CAT5e or higher,
on a switch of your choice
(CID:89555477)
Hi Craig,
All the information to configure a PDU on the network is detailed in KBase FA156064. The cable information is also available on the KBase. link to get to this KBase is below:
http://www.apc.com/site/support/index.cfm/faq/
There is also information in the manuals, available on apc.com for the particular PDU you have. For example, if the PDU is the AP88xx range, the manual is below:
http://www.apcmedia.com/salestools/JSAI-7WFQKR/JSAI-7WFQKR_R4_EN.pdf
B
(CID:89555479)
Posted: 2020-07-02 08:25 AM . Last Modified: 2023-10-31 11:02 PM
