Posted: 2020-07-05 01:30 PM . Last Modified: 2024-04-04 12:31 AM
Can it be shown total load equal the estimated load?
edited:
Can I adjust the total power equal the estimated load without calculation failover load and PSU Uncertainty ?
(CID:134690355)
Hi Semih,
As illustrated, the tool-tip (in Power overlay) should display the Total loads and the Estimated loads (on each connected phases).
Kind regards
(CID:134690625)
Hi Jef,
My question is for the Power Dependency
My DCO capacity overview seen as %105
Kind regards
(CID:134691492)
Dear Jef Faridi
The question here is about PSU and failover load's. Is there any way to avoid it, or which parameters are effecting PSU and Failover? We will be glad if you highlight us the logic behind the PSU and Failover calculation.
Warmest regards
Behram
(CID:134693619)
Hi Semih,
I don't think they can be manually adjusted, calculations are based on the setup itself. Just to mention what the Total load is (in the Power Dependency tab):
Total load is sum of the "Estimated load" + Failover load + PSU Uncertainty + Reserved for Dist. Redundancy.
Total load can be equal to Estimated load, if the other 3 items in the equation have no values.
Hi Behram,
Fail overload and PSU Uncertainty calculations are basically depend on the setup itself. For more details and description please see the following pages (and other related pages):
Understanding the new Capacity implementation
About power supply unit uncertainty
Kind regards
(CID:134693712)
Posted: 2020-07-05 01:30 PM . Last Modified: 2023-10-22 04:07 AM
