Posted: 2020-07-04 03:30 AM . Last Modified: 2024-04-05 03:18 AM
(CID:128060327)
The netbotz 250 were added to DCE, but at this moment, the only way that I can configure the Rack access cards and users is by web browser of each netbotz 250.
(CID:128060337)
Posted: 2020-07-04 03:30 AM . Last Modified: 2024-04-05 03:17 AM
Hi Edwin,
Yes, DCE can mass configure the NetBotz 250 and it's cards. I suggest first configuring one 250 though. After that, you can go into StruxureWare and APC device configuration. Look at the configuration of the existing device or create a template based on that device.Here you can see the rack access options for 2 cards along with some menu options above it. These will be listed under the "Advanced Settings: field:
If you double click the line item for one card, you can see the full configuration and format:
Steve
(CID:128060339)
Posted: 2020-07-04 03:31 AM . Last Modified: 2024-04-05 03:17 AM
Tanks Steve,
Can I generate reports of all Rack access using filter by user and by rack, with DCE?
(CID:128060351)
Hi Edwin,
No, that's not a report option in DCE.
Steve
(CID:128060353)
Posted: 2020-07-04 03:31 AM . Last Modified: 2023-10-22 04:06 AM
