The Difference Between StruxureWare for Healthcare and StruxureWare Operation/Expert
  • The Difference Between StruxureWare for Healthcare and StruxureWare Operation/Expert
129
72
Posted: ‎2020-07-02 11:17 AM . Last Modified: ‎2024-04-10 12:36 AM
928
Hi Team,
Kindly help me understand the difference between StruxureWare for Healthcare  and StruxureWare Operation/Expert.
Felix
(CID:94602935)
  • Data Center Operation
929
Hi Felix,
StruxureWare for Healthcare is a suite of products that are suitable for the Healthcare business.
More info can be found here on which products are in the suite.
StruxureWare Operation/Expert I guess you refer to StruxureWare Data Center Operation and Expert?
These products are part of the StruxureWare for Data Centers suite which is software products suitable for the data center business. More info can be found here
You will experience that products (like e.g. StruxureWare Data Center Expert) are part of more suites. The feature set of the product might be relevant to several business areas and therefore there is not a hard line between the suites and the included products.
In general all StruxureWare suites are divided into 3 layers Enterprise, Operations and Control. More info can be found around StruxureWare here. StruxureWare Data Center Operation is in the Operations category and Data Center Expert is in the control category.
(CID:94602953)
Replies 4
930
Hi Felix,
(CID:94602953)
Thanks. It is a good link to struxureware-applications.page - absolutely not easy to find!
(CID:94603148)
Hi Bruncke, Thanks a lot for the links Regards, Felix
(CID:94603156)
Posted: ‎2020-07-02 11:17 AM . Last Modified: ‎2023-10-31 11:38 PM
