Tested DCO Server
  • EcoStruxure IT forum
  • Tested DCO Server
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 02:53 PM . Last Modified: ‎2024-04-09 04:03 AM
516
Tested DCO Server
Hi Team,
Do we any list of tested servers for DCO? The reason we are asking this, we have encountered network card and raid drivers issue during installation and end up installing vmWare esxi to house the DCO server.
The server model below, would you able to verify, if this comply to DCO network and raid requirement. Thanks.
 HP Proliant DL380p Gen8v2 Server
(CID:100340203)
  • Data Center Operation
Replies 4
516
Hi Rayson,
From HP Servers Support & Certification Matrices, your server should be compatible with VMware.
http://h17007.www1.hp.com/us/en/enterprise/servers/supportmatrix/vmware.aspx#.VdacV_mqqkp
BR,
Nathawat
(CID:100340205)
Thanks Nathatwat, Actually we are not planning to install VM. The server will be dedicated to DCO and it will installed using our USB procedure. In the past we have found issues in installing DCO on certain servers which we are trying to prevent this time. In addition this server will be configured on cluster and our experience, DCO in VM configured in cluster prompts a lot of network issue. best regards, rayson
(CID:100340211)
If you take a look at System Requirements, you will find a list of working and non-working RAID controllers.
(CID:100340213)
Posted: ‎2020-07-02 02:54 PM . Last Modified: ‎2023-10-31 11:38 PM
