Posted: 2020-07-03 12:28 AM . Last Modified: 2024-04-09 12:55 AM
Hello Community,
We have received the following query from a customer Ukraine. Not sure exactly what he is asking so hope the translation to English makes sense to someone else. If not, please let me know.
There are Symmetra PX associated to DCO via DCE and it have 3-ph output module with different load consumer on each phase. If open DCO Symmetra properties and choose Placeholder Panel - there is no option to set these users independently. There are workaround to set 3 x 1ph output modules, but in that case it is impossible to measure load through DCE.
Is that posible to fix that with future DCE releases?
Original question in Ukranian below.
1. На объекте установлена Symmetra PX, ассоциированная в DCO через DCE.
2. В ней установлен 3-хфазный автомат к которому подключены 3 разных потребителя по фазам.
3. В DCO в свойствах Symmetra во вкладке Placeholder Panel нет возмозножности при установке 3-хфазного автомата указать разных потребителей.
4. Решение с установкой 3х однофазных автоматов является неприемлимым так как при этом на подключенных потребителях не возможно получить измеренную нагрузку из DCE.
(CID:105467166)
Hi John Thompson Translation is correct, but I'm not sure I understand the question. The data centre model in DCO should reflect real equipment. I suspect that user might have updated DCO, but did not model modular breaker panel, leaving it as generic. Modular breaker panel does allow to have separate consumers per phase on one 3x1p breaker. I would recommend this video tutorial: https://www.youtube.com/watch?v=aT8sZjYmI5c
(CID:105467872)
Hi Stanislav Kalianov , Could I ask you to check the translation on this query also. Just want to make sure it makes sense to everyone. Thanks again.
(CID:105467240)
(CID:105467872)
Great thanks for your answer. Yes, we have forget, after upgrade reorganize breakers panel for symmetra px 80 and so "did not model modular breaker panel, leaving it as generic". We try to use example from this video.
(CID:105467874)
Posted: 2020-07-03 12:28 AM . Last Modified: 2024-04-09 12:54 AM
Hi John, are you saying the UPS has PDM/s installed?
(CID:105467871)
Posted: 2020-07-03 12:28 AM . Last Modified: 2023-10-31 11:38 PM
