Supplemental OIDs value decimal point
  • EcoStruxure IT forum
  • Supplemental OIDs value decimal point
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 01:09 PM . Last Modified: ‎2024-04-09 04:39 AM
808
When i add a supplemental OID to DCE for a device, it comes up with the value not calculated.
I.E. Value received is 43 and should be shown as 4.3
How would i get DCE to display it correctly without a multiplier or something... or am i missing a step?
(CID:97485479)
808
Hi Chad,
DCE has no means of scaling or performing calculations on supplemental OIDs.
You would need to request a DCE DDF file from multivendorsupport@apc.com, you can then specify an appropriate multiplier in the request form
(CID:97485511)
Replies 4
809
Hi Chad,
(CID:97485511)
To add to David's answer, in general if you find missing data points from a device (especially when you think other customers would be interested in the data point) we'd really appreciate you requesting a DDF change rather than using Supplemental OIDs so that we can update the DDF for all customers.
(CID:97485797)
Posted: ‎2020-07-02 01:10 PM . Last Modified: ‎2024-04-09 04:39 AM
I think it would be more appealing to do that if it didnt take up to 2 months to get DDFs back and when you get them back the OID sensorID didnt change and disconnect all furtue and past data... As was the case last time i did that.
(CID:103585684)
Posted: ‎2020-07-02 01:10 PM . Last Modified: ‎2023-10-31 11:37 PM
This is a heading
