Posted: 2020-07-03 09:39 PM . Last Modified: 2024-04-07 11:42 PM
Hi there,
I installed StruxureWare DCE server using the following link: Deploying and configuring a StruxureWare Data Center Expert virtual appliance
Then I installed the DCE client on another virtual machine (Windows 10). I added an HTTP Post alert action and whenever I try to test it, it says check the destination but in the logs:
Aug 10 14:09:07 server1 nbSendHTTPAlert: Send HTTP Alert started
Aug 10 14:09:07 server1 nbSendHTTPAlert: Error posting to url https://hookb.in/Ezg5moDG: HTTP code=0, err=6
Also when I click on StruxureOn > Registration it says:
"Error communicating with www.struxureon.com. Please check your firewall and proxy settings.
I'm pretty sure that my windows machine has internet connection and has a disabled firewall. I also tried with another VM, so probably the problem is with the server VM (CentOS).
Any help would be appreciated.
Sincerely,
(CID:123347002)
Have you configured the gateway IP on the DCE server?
(CID:123347029)
Posted: 2020-07-03 09:39 PM . Last Modified: 2024-04-07 11:41 PM
I set the default gateway to my system's private IP.
My private IP is :192.168.1.105
VM Configuration
VM IP: 192.168.1.155
Subnet Mask: 255.255.255.0
Gateway: 192.168.1.105
(CID:123347109)
Hi Bener Celenkoglu,
In your case, you must provide network access to the Internet, not for a DCE-client, but for a DCE-server.
I.e., in the first case according to StruxureWare Data Center Expert Security, it is necessary to check the outgoing network access from the DCE-server to the host https://hookb.in/Ezg5moDG using the HTTPS protocol (443 port).
In the second case, according to https://struxureon.com/system-requirements/, it is necessary to check for outgoing network access from the DCE-server to hosts 40.84.62.190 and 23.99.90.28 using the HTTPS protocol (443 port).
With respect.
(CID:123347073)
Posted: 2020-07-03 09:40 PM . Last Modified: 2024-04-07 11:41 PM
Hi spezialist,
Unfortunately, I couldn't solve the problem. However, my main goal is to develop an integration with DCE so I used my private IP address to send the HTTP POST. That's enough for me now to develop the integration. Thanks you for following the issue, I appreciate it.
Yours sincerely,
(CID:123347618)
Posted: 2020-07-03 09:40 PM . Last Modified: 2023-10-22 04:02 AM
