StruxureWare Portal is not showing correctly using Internet Explorer v11
  • EcoStruxure IT forum
  • StruxureWare Portal is not showing correctly using Internet Explorer v11
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 08:40 AM . Last Modified: ‎2024-04-10 01:25 AM
580
Internet Explorer is only showing the layout and no data. No graphs, temp or humidity readings, no power usage, U space. all of these are blank.
After doing a lot of research found that in Windows 8.1 un-ticking "Enhance Protection Mode" resolves the issue for IE 11 64bit. however most of the machines that need to access the portal are Windows 7 32bit.
Does anybody have any suggestions on how to fix this for Windows 7 32bit machines running IE11?
(CID:90898845)
  • Portal
Hi Martin, welcome to the community! We will investigate it, thanks for posting.
(CID:90898885)
Hi Martin,
Not sure why the IE11 on Windows 7 32 bit machines are not working?
It seems like the EPM functionality is only used/supported on 64 bit OS? http://www.eightforums.com/tutorials/31977-internet-explorer-enhanced-protected-mode-turn-off.html
Have you tried other browsers (chrome, firefox) on the 32 bit machines and seen the Portal working?
There is also compatibility mode which might be enabled. This can be checked using the menu that appears after pressing F12.
(CID:90899012)
Posted: ‎2020-07-02 08:40 AM . Last Modified: ‎2023-10-31 11:37 PM
This is a heading
