Posted: 2020-07-02 11:19 AM . Last Modified: 2024-04-10 12:36 AM
Hi all, StruxureWare Operations: EcoStream is working only several days and then writes that it is expired.
I use the last version of it. How can I make it work all time? Thank you!
(CID:94603163)
As for now each version of EcoStream has limited time. Just download and install new version that will give you 3 moth more.
(CID:94603167)
Posted: 2020-07-02 11:20 AM . Last Modified: 2023-10-31 11:37 PM
