Posted: 2020-07-02 06:03 PM . Last Modified: 2024-04-09 02:06 AM
For network security reason, one customer may to change the security communication protocol in the StruxureWare Data Center Expert from SSL protocol to TLS protocol. The TLS protocol is mandatory in all the ISX application including the "webmin". The Expert was updated to the last version, but our customer require to check (and change) the protocol from SSL and TLS including the webmin application. Where can I change and check the security protocol type using in the ISX and the Webmin?
(CID:104863490)
Hi Luis Lopez Borbon, thank you for posting. I'll see who can be of assistance here. Meanwhile, @community - do you have any suggestions?
(CID:105456595)
Hi Luis,
SSL via console application or the web page for StruxureWare DCE uses TLS. There is no way in the UI to verify this, you would need to run a scan with a 3rd party utility. You can not turn it off / on in the UI. If you have specific questions about versions of TLS in specific versions of DCE or the supported certs in general, please feel free to ask.
Steve
(CID:105456650)
Posted: 2020-07-02 06:04 PM . Last Modified: 2024-04-09 02:06 AM
P.S. Webmin is used with DCO and not DCE. Were you also looking for DCO information? Steve
(CID:105456667)
Posted: 2020-07-02 06:04 PM . Last Modified: 2023-10-31 11:36 PM
