Smartlink A9XMWA20 integration in DCE?
  • Smartlink A9XMWA20 integration in DCE?
127
Posted: ‎2020-07-03 06:08 PM . Last Modified: ‎2024-04-07 11:58 PM
1061
Did someone add a smartlink gateway A9XMWA20 in DCE 7.4 for reading data from PowerTag A9MEM1520 power meters?
I need to do it for monitoring the load of a datacenter with more than 60 circuit breakers in one panel and it is not possible to use bigger power meters because of lack of space.
I was not able to find a driver for A9XMWA20, so if someone can help me it would be very good 😀
(CID:122691599)
Replies 4
1059
There is already  smartlink DCE DDF for modbus TCP:
https://dcimsupport.apc.com/devices/view/Acti9%20Smartlink%20Modbus/Schneider%20Electric
Give it a try, and contact device support if you need to get any modification done on the DDF.
(CID:122691618)
The smartlink is not the same model and the driver I need is actually for the power meter A9MEM1520, not the gateway itself.
I will contact the device support for this topic.
Here is the modbus register list for the A9MEM15xx devices in Smartlink Si 😧
Acti 9 Smartlink SI D - Device Registers.pdf
Thank you
(CID:122691639)
Did the ddf for power tag get created as I can not see it in the list of supported devices, and I also have  the same use case.
Andy
(CID:130094109)
Posted: ‎2020-07-03 06:08 PM . Last Modified: ‎2023-10-22 03:56 AM
