Short message e-mail, ℃, ℉
  • Short message e-mail, ℃, ℉
128
Posted: ‎2020-07-03 02:23 AM . Last Modified: ‎2024-04-09 12:18 AM
784
I'm in the Republic of Korea.
So you can only use a translator . Take care to understand .
I 've got a Netbotz (4.5.0). About 25 .
I show all I see ℃ temperature through the program and the Web . So I set . maybe region(?) and language(?).
However, when it receives an alarm to " short message e - mail " .
Some of the temperature being transferred to the fungal netbotz ℉ .
Netbotz sent to ℉ fungal continue to transfer ℉.
I want to know why .
And I want to fix.
 Thanks for the story . Thank you .
And once again I'm sorry translator .
(CID:105474490)
  • NetBotz
784
Hi Yongjn,
In order to receive the short message email in degree Celsius, please make sure that the appropriate locales selected while you are adding the email address.
Additional info:
The following outlines how to change the temperature unit of measure (Fahrenheit to Celsius 😞
  1. Change the regions settings in Advanced View to the appropriate region. Go to Configuration-Region-Change Locales to English(United Kingdom) and Time Zone to (GMT +5:30) India Standard Time(Asia/Calcutta) or as per the region.
  2. Ensure that the correct time zone is selected on the PC that is running the Advanced View. These changes are made via the Windows Control Panel. 3. Ensure that the Regional Settings are correctly configured on the PC that is running the Advanced View. These changes are made via the Windows Control Panel.
    Go to Start-Control Panel-Date and Time-Ensure that correct Time Zone is selected
    Go to Start-Control Panel-Region and Language-Formats-Change the Format to English (United Kingdom)
    Apply the Settings. And then close the Advance View of Netbotz and Re-Launch the Advance View. By now, the reading would have been changed from F to C.
I hope this helps.
Bala
(CID:105474496)
Thanks. But now I can not access the Netbotz. A long time can not be accessed. Perhaps one or two months . There 're a closed network. I'll just check the following access opportunities. For feels like to fix the problem. Once again, thank you very much. p.s. Translator is still referred sorry.
(CID:105474509)
Posted: ‎2020-07-03 02:23 AM . Last Modified: ‎2023-10-31 11:35 PM
