Setting alarm priority in SBO for DCE alarms
  • EcoStruxure IT forum
  • Setting alarm priority in SBO for DCE alarms
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 02:16 PM . Last Modified: ‎2024-04-09 04:15 AM
355
We're seeing SBO assign a priority against DCE alarms, the same priority for eacj DCE alarm of the same severity, e.g. DCE Warning = SBO Priority 300.  How can this be changed
(CID:99157297)
Hi Ed,
Hopefully someone with SBO experience is on this forum but I'm curious, does a warning show as 300 and informational show as 100? Would failure then show as 500? If that's the case, it seems like it's giving it a severity of 1 through 5 (hundred). The only way to change that at the DCE level would be to change the severity of the alert from warning to something else. If you need to send the warning alert but need SBO to use a different severity number, someone with SBO experience would need to tell you how or if that is done.
Steve
(CID:99157335)
Posted: ‎2020-07-02 02:17 PM . Last Modified: ‎2023-10-31 11:35 PM
