Posted: 2020-07-03 04:28 AM . Last Modified: 2024-04-08 11:39 PM
Hello team,
i have an issue with DCO 7.2.5, when i install it in a VM, the IT team has to change it's adresse IP to put the VM in the same LAN as DCE. But when i start the machine i have this :
Service not started,
i tried with what it's recommended in your site but still the same problem:
"ssh log in to the server, and run the following command to clean up, and then reboot:
sudo su
service operations purge
reboot"
i tried also with the patch but still the same problem
it looks that the service is running but i have the first image agin and again :
Can you please help?
Best Regards
Nassim
(CID:106210673)
Hi bendourou, thanks for posting! Let's see who can be of assistance here. @community - any ideas for Nassim? Best, Stine
(CID:106210747)
Posted: 2020-07-03 04:28 AM . Last Modified: 2024-04-08 11:38 PM
Hi bendourou Woudl it be possible to share the server logs? They can be downloaded via the "StruxureWare Data Center Operation" Webmin page. Regards, Ulrik
(CID:106210763)
Hi Bendorou,
I was wondering if this has been resolved? Otherwise, additional to Ulriks comments, I would suggest "moving" the product to the latest version (currently DCO 8.0). As described in the following page, you would need to install DCO 8.0 on a new server and then restore your latest backup (from the current setup, eg. 7.2.5) :
Getting from previous versions to DCO 8.0
Kind regards
(CID:108235252)
Hi Bendorou, Please ignore my question, I've just been told that the problem had been resolved - it was something to do with the vmware setup. Kind regards
(CID:108235257)
Posted: 2020-07-03 04:28 AM . Last Modified: 2023-10-31 11:35 PM
