Server Genoma in DCO
  • Server Genoma in DCO
129
72
Posted: ‎2020-07-03 07:50 AM . Last Modified: ‎2024-04-08 04:03 AM
962
A customer needs to know how to enable or show the "Genoma" of several HP Proliant added to DCO in order to show their efficiency, I really don't know if this logic is accurate so I need your help with this.
Case # 32401747
(CID:110004721)
  • Data Center Operation
Hi Francisco,
If I understand correctly, the intention is to associate live data from the external system to the layout in DCO. I guess customer has some IT assets discovered by ITO server, which would be appear in: Planning Device Association > Unassociated Devices  pane (> "ITO server").
To associate any of the items (IT assets such as server) one by one with the item that represents it in the layout, drag-and-drop the item from the Unassociated Devices pane into position over the corresponding items in the Navigation pane or Layout pane.
Following page contains more details:
Associating Live Data from an External System to the Layout
Kind regards
(CID:110004814)
Hi Francisco,
Kind regards
(CID:110004814)
Thanks for your answer. I'll replicate this info to the customer and see if it's what he's looking for.
(CID:110005457)
Posted: ‎2020-07-03 07:50 AM . Last Modified: ‎2023-10-22 03:54 AM
