Server Backup DCE
  • EcoStruxure IT forum
  • Server Backup DCE
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 05:27 PM . Last Modified: ‎2024-04-09 02:27 AM
725
Server Backup DCE
Hello
I have set up a Windows share for my server backup, and it worked in 7.2.0 and in 7.2.1 (Sometimes) but now i have upgraded to 7.2.2 and now it keeps failing the backup.
I have used the test button, when you set up the backup part, and that part works, i comes out with an success.
Question is, where can i see the backup log, so i can pin point the backup problem.
Glenn
(CID:104174179)
724
Hi Glenn,
It should be written in the NBC log on the Data Center Expert server.
You can access it by:
  • Opening a web browser and go the the IP/hostname of the Data Center Expert server
  • Log in
  • Click the tab called Logs in the top right corner
  • Then check on of the nbc.xml log file.
Jesper
(CID:104174185)
725
Hi Glenn,
  • Log in
Jesper
(CID:104174185)
Thanks, that did the trick the nbc.xml
(CID:104174240)
Posted: ‎2020-07-02 05:27 PM . Last Modified: ‎2023-10-31 11:35 PM
This is a heading
