SNMP data type opaque
  • EcoStruxure IT forum
  • SNMP data type opaque
124
65
Back to EcoStruxure IT forum
Gabi
Lieutenant Gabi
Lieutenant
Posted: ‎2023-03-10 08:43 AM
2253
there is a plan to implement on DCE, option to handle data type opaque?
thanks
Replies 6
Shaun
Commander Shaun Commander
Commander
Posted: ‎2023-03-10 10:47 AM
Hi Gabi,
Could you help me understand, what kind of data you envisage capturing this way, and what value that data brings?
DCE is typically interested in data which is either scalar or stateful - things we can measure, graph, compare and act on.  Opaque types are usually difficult for this because if the data means nothing to the DCE, then all we're doing is warehousing it - which does not play to the DCE's strengths at all.
It is something that could be looked at, but we'd need to better understand the payoff, or "user story".
Gabi
Lieutenant Gabi
Lieutenant
Posted: ‎2023-03-10 08:16 PM
2240
Hi Shaun,
like usual Vertiv reinvent the wheel in the monitoring system and the new CRAC/CRAH units comes equipped with different Carel controllers and monitoring modules
this new monitoring modules use data type opaque and from interface I can change to integer/unsigned but response contains only 2 digit like temperature 21.5 with opaque remains 21 on integer/unsigned(I`m not sure but even worse the value is rounded up )
DCE ignore all oid configured in DDF that are set as opaque on Vertiv monitoring module
Shaun
Commander
Posted: ‎2023-03-12 11:39 AM
In response to Gabi
HI Gabi,
Thanks, that makes a lot more sense.  I can see what they're trying to do - the only native snmp type for decimal values is using floats, which are an expensive operation for many embedded controllers.  (This is why a lot of APC oids use "tenths of an amp" & similar, to provide decimal precision without having to send decimal values).
Would it be possible to do an snmp walk from the DCE's web interface (the Status link top-right, and pick snmp walk from the menu) and share how this particular oid appears there?  (No need to share the whole thing, just the entry for this specific example will do me).
  Shaun
Gabi
Lieutenant Gabi
Lieutenant
Posted: ‎2023-03-12 08:53 PM
Hi Shaun,
for example return temperature which is ending with .540.0 on previous screenshot is shown in different ways by mib browser, DCE snmp walk and Schneider windows walk app for DDF support
windows walker Schneider(seem like doesn`t know to decode the value)
1.3.6.1.4.1.476.1.42.4.3.32.540.0, Opaque      , ďż˝xAďż˝ff
mib browser
Name/OID: .1.3.6.1.4.1.476.1.42.4.3.32.540.0; Value (Opaque): 22.3
web walker DCE
.1.3.6.1.4.1.476.1.42.4.3.32.540.0 = Opaque: Float: 22.299999
Gabi
Lieutenant Gabi
Lieutenant
Posted: ‎2023-03-20 03:19 AM
Hi @Shaun,
do you have any answer regarding this problem?
thanks
Shaun
Commander
Posted: ‎2023-03-21 01:40 PM
Hi @Gabi,
I was off ill last week, sorry for the delay.
My plan going forward is to replicate this and see what our options are.  If it's possible to manipulate in the DDF I'll share what I find (on a "best effort" basis - we don't support customers creating their own DDFs, so what you do with those findings will be your problem).  But if it requires a feature/enhancement request in the DCE, there'll be very little I can share from there.  There's a line between being helpful, and "how the sausage is made", that I need to tread carefully.
