Posted: 2020-07-04 03:51 PM . Last Modified: 2024-04-05 12:26 AM
The community name of the remote SNMP server can be guessed.
It is possible to obtain the default community name of the remote SNMP server.
An attacker may use this information to gain more knowledge about the remote host, or to change the configuration of the remote system (if the default community allows such modifications).
Disable the SNMP service on the remote host if you do not use it. Either filter incoming UDP packets going to this port, or change the default community string
(CID:129412678)
DCO?
Do any of the following from Webmin
Enabling Data Center Operation monitoring through Data Center Expert
Edit 1:
DCE:
SNMP access to DCE can be enabled/disabled or you can change the community name from:
(CID:129412762)
DCO?
Edit 1:
DCE:
(CID:129412762)
In addition to Chris' comments, the "public" read string is a common default. It can simply be changed to something other than "public" as you yourself noted.
(CID:129412882)
Always change the SNMP V1 community string.
Depending on customer requirements and security considerations I often recommend not using SNMP V1 write.
You can further secure your SNMP agents by allowing only SNMP read (GET etc) from selected IP addresses, e.g. DCE.
(CID:129413909)
Posted: 2020-07-04 03:51 PM . Last Modified: 2023-10-22 03:48 AM
