Posted: 2020-07-02 08:53 AM . Last Modified: 2024-04-10 01:22 AM
In the SBO workstation software requirements (see link below) it states under the 'Additional Software Required' that
(CID:90899606)
Hi John,
Thanks for the info. Just wanted to make sure which version of SBO you are running?
For 1.4: 'Additional Software Required' is Microsoft .NET Framework 4 with update KB2468871
For 1.5: 'Required additional software' is Microsoft .NET Framework 4.5
There is a product version drop down in the top of the page which is default selecting v1.4 (at least in my browser)
(CID:90899633)
Hi John,
(CID:90899633)
Ah, that is confusing to hide it in the top right corner. However you are correct. User error on my part. I am using version 1.5. Thanks for the reply.
J
(CID:90899661)
Hi John, please use 'add comment' instead of 'your answer' when commenting on somebody's answer if it's not a solution of the problem. We reserve the 'answer' feature only for (potential) solution(s). Thank you for your understanding.
(CID:90899753)
Posted: 2020-07-02 08:53 AM . Last Modified: 2023-10-31 11:34 PM
