Integration to Vijeo Citect
  • Integration to Vijeo Citect
129
112
72
Posted: ‎2020-07-02 08:54 AM . Last Modified: ‎2024-04-10 01:22 AM
1514
Hi!, I want to know the best way to integrate all the info relating to devices on DCE 7.2 into Vijeo Citect 7.4 as the latter would be my main monitoring software platform, integrating cameras and access control.
I was looking into the modbus tcp module but would like to get very detailed info as to what can be exported or if there's a more seamless way to do it.
(CID:90899622)
1514
Hi Luis,
The best way would probably be to use the web services API to pull the information from DCE. This web services API can be downloaded on the below link: (SFWEBSVC):
http://www.apc.com/tools/download/software_comp.cfm?sw_sku=SFWEBSVC&id=350&family=&part_num=&swfam=A...
B
(CID:90899636)
Replies 4
1515
Hi Luis,
B
(CID:90899636)
Thanks for the quick answer! Is there a guide about using that API? and what kind of information would this API pull? a web page to display on Citect? Thanks!
(CID:90899667)
Posted: ‎2020-07-02 08:55 AM . Last Modified: ‎2024-04-10 01:22 AM
Hi Luis, All the information is bundled with the zip file you download. I believe you script the API to pull the information you wish from DCE, and also development a web page to show this info.
(CID:90899672)
Posted: ‎2020-07-02 08:55 AM . Last Modified: ‎2023-10-31 11:10 PM
