We Value Your Feedback!
Could you please spare a few minutes to share your thoughts on Cloud Connected vs On-Premise Services. Your feedback can help us shape the future of services.
Learn more about the survey or Click here to Launch the survey
Schneider Electric Services Innovation Team!
Reset user password in Data Center Expert
  • EcoStruxure IT forum
  • Reset user password in Data Center Expert
  • Subscribe to RSS Feed
124
109
62
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 09:43 PM . Last Modified: ‎2024-04-09 01:41 AM
1567
I would like to reset the Data Center Expert user account all version. Is it be possible ?
Thank you beforehand
Regards.
Davy
(CID:105459140)
Replies 12
1567
Yes.  Log in with a user that has admin privileges and go to :
System
Users and Device Acccess
and then select the user you want to reset/change the password for and click Edit.
(CID:105459142)
Thank you Michael.
But I don't know the admin account password. I would like to reset user admin in DCE. Is it be possible ?
Sould I perform a factory reset ?
(CID:105459168)
I will defer to the folks from APC/Schneider on doing a factory reset.
(CID:105459170)
Posted: ‎2020-07-02 09:44 PM . Last Modified: ‎2024-04-09 01:41 AM
A client lost passwords and I wanted to know if it was possible to reset the password ADMIN without a factory reset. Apparently not. Thank you for your answers.
(CID:105459169)
1567
Hi Davy,
You need to have physical access to the server:
Please follow these steps in order to reset the password on ISX Central v5.1 higher:
1. Hook up monitor/keyboard to ISXC or setup hyperterminal serial session.
2. Reboot ISXC (by cycling power)
3. Login within 5 minutes of ISXC reboot with the following username/password:
username: apcreset
password: apc
4. Follow instructions when prompted to reset apc admin user to factory defaults (i.e. apc/apc)
5.Login to the Central client with the apc/apc as admin user/password,  goto  Settings-Users and Device Group Access to change the Central's user and password specifically.
Steve
(CID:105459151)
Hi Steve, Thank you for this procedure.
(CID:105459152)
1567
Davy, The process described by Steven Marchetti above (reboot and logon locally) will enable you to change the the administrator password (as well as network details if required). It is not a factory reset back to "out of the box". As such, you would not lose your device configuration. I have performed this myself, and it works fine. Once the apc admin password has been changed locally on the appliance, you can then log on via the Thick client, and then add normal accounts, change passwords etc. It is a simple process, and should provide you with the outcome you require.
(CID:105459197)
Thank you Warren. I will test this procedure in a few days.
(CID:105459229)
Dear Warren,
       Can you explain the procedure to connect the Server with serial port. What baud rate should be selected & other options.
thanks
(CID:111938662)
Saqfi,
If I remember correctly the settings are
9600 - bps  If this doesn't work try 2400 bps speed
8 - Data bits
None - Parity
1 - Stop bits
None - Flow Control
(CID:111939364)
Hi guys, This should be done by connecting a Keyboard and Monitor to the hardware server. You can not connect to anything above version 5 I believe using the serial connection.
(CID:111939366)
Posted: ‎2020-07-02 09:44 PM . Last Modified: ‎2023-10-31 11:33 PM
This is a heading
