Registration Code location
  • Registration Code location
129
72
Posted: ‎2020-07-04 10:29 PM . Last Modified: ‎2024-04-04 03:20 AM
4182
(CID:134024654)
  • IT Expert
Replies 29
Dear John Beck,
Please describe your problem in more detail with a couple of screenshots. And then you will be helped faster and better 😀.
With respect.
(CID:134024662)
(CID:134024907)
4181
Dear John Beck,
See answer in your picture:
To clarify the requirements, see topic :
Firewall
  • Port 443 TCP outbound
  • To connect using static IPs, add 40.84.62.190 and 23.99.90.28
With respect.
(CID:134024686)
Outbound is Port 443 TCP
(CID:134030605)
Posted: ‎2020-07-04 10:29 PM . Last Modified: ‎2024-04-04 03:19 AM
Yes, this is correct, so it is written in the instructions below.
(CID:134030607)
Posted: ‎2020-07-04 10:29 PM . Last Modified: ‎2024-04-04 02:52 AM
And it still doesn't work. See below:
(CID:134030666)
Dear John Beck,
You have a network problem, probably you need to contact your network administrators for help.
To start go to the web-page https://support.microsoft.com/en-us/help/310099/description-of-the-portqry-exe-command-line-utility and download either Portqry.exe or PortQueryUI tool for MS Windows.
Then perform a simple test for destination 40.84.62.190 from your EcoStruxure IT Gateway for listening TCP port 443 (HTTPS service) as in the screenshot below:
If it's okay, you should see something like this TCP port 443 is LISTENING.
I hope this helps you and will speed up the solution of your problem. Try and report the result please.
With respect.
(CID:134030625)
Posted: ‎2020-07-04 10:30 PM . Last Modified: ‎2024-04-04 02:52 AM
I received the same thing - as follows:
(CID:134030648)
Dear John Beck,
Ok, then another couple of questions:
  • what type of Windows OS are you using?
  • perform in the Windows cmd query of the status of the gateway services:
textSchneider Electric EcoStruxure IT Gateway services statussc query EcoStruxureITGateway-1.4.0 sc query EcoStruxureITGateway-db-1.4.0
  • how much free disk space?
With respect.
(CID:134030653)
Also, what are your proxy settings for the gateway software?
And please make log downloads from the web-GUI of your gateway software. Then you can analyze it and find some problems or errors...
With respect.
(CID:134030664)
(CID:134030658)
The Windows OS is Windows 7 Enterprise
(CID:134030643)
(CID:134030637)
Proxy Server Settings:
(CID:134030631)
logs 9-5-2018.zip
(CID:134030618)
Posted: ‎2020-07-04 10:31 PM . Last Modified: ‎2024-04-04 02:52 AM
I have attached the logs from the web-GUI of the Gateway Software
(CID:134030612)
Dear John Beck,
Tell us, please, have you solved this problem or not?
With respect.
(CID:134026418)
4181
Dear John Beck,
Your OS is untypical and is not officially supported by the vendor to work with the EcoStruxure IT Gateway software. But I believe, that the problem is in your proxy settings for the gateway, i.e. from your screenshot are automatic settings.
Therefore, I highly recommend carefully reading the updated instruction How to set up the EcoStruxure IT Gateway proxy settings. From your PC, you can very simply check the availability of a network connection to the cloud servers:
Verify the gateway’s connection to the EcoStruxure IT server
Open a browser and type the URL for the EcoStruxure IT registration endpoint. https://us.struxureon.com/ingester/v1/adssd/registration
If the connection to the server is unsuccessful, a ‘no internet connection’ error is displayed. If the connection to the server is successful, the page displays status, supported country, and link information if any.
{"status":"UNREGISTERED","supportedCountry":true,"link":{"url":null,"text":null}}
Please check and report the result.
With respect.
(CID:134027474)
I did what you stated above and received the following:
(CID:134027592)
Posted: ‎2020-07-04 10:31 PM . Last Modified: ‎2024-04-04 02:51 AM
How do I add these:
(CID:134027723)
I should have said "Where do I put these static IP addresses?
(CID:134027727)
Dear John Beck,
Judging from your answer above, you have a normal network connection to the cloud servers of Schneider Electric.
I still doubt about your proxy server configuration for the EcoStruxure IT Gateway software... You can not use a proxy server at all for your gateway (No proxy)?
With respect.
(CID:134028008)
Good Morning Spezialist,
As of 6pm last night EcoStruxure IT Gateway is now working - see the following from this morning:
(CID:134028149)
I don't know why or how. Nobody on my side (IT or Network) did anything.
(CID:134028152)
Posted: ‎2020-07-04 10:32 PM . Last Modified: ‎2024-04-04 02:51 AM
I am still getting the "Detected an unauthorized user attempting to access the FTP interface" each time a UPS is polled (which I believe is done on a daily basis). And I have made sure that the Device File Transfer Settings are matching and correct.
(CID:134028167)
I just changed the Username and Password in the Device File Transfer Settings for the two (2) devices (UPS's) that I currently have in EcoStruxure IT to the one in each device (UPS's). It has administrative rights.
(CID:134028189)
We will see if that stops these daily unauthorized FTP access emails.
(CID:134028190)
Dear John Beck,
Ok, great that you solved the problem 😀.
For "Detected an unauthorized user attempting to access the FTP interface", report please the result later.
With respect.
(CID:134028193)
Posted: ‎2020-07-04 10:32 PM . Last Modified: ‎2023-10-22 03:45 AM
