Posted: β2020-07-04 08:29 PM . Last Modified: β2024-04-04 04:10 AM
We have been trying to gather if we can get the Rack weight per rack using the ETL. Anyone who has experience on this area?
(CID:132667423)
Hi Vineet
Sorry for the delayed answer.
Yes that is possible. The data is available in the swo_kpi table.
The query below should get you started.
select ci_name, kpi_value, kpi_serie_type, ci_type from swo_kpi k, configuration_item ci where kpi_serie_type = 'TOTAL_WEIGHT' and k.ci_id = ci.ci_id;Best,
Niels
(CID:133367416)
Hi Vineet
Niels
(CID:133367416)
Thanks Niels , Let me work using this.
(CID:133367474)
Posted: β2020-07-04 08:29 PM . Last Modified: β2023-10-22 03:43 AM
