Rack unit not decreasing
  • Rack unit not decreasing
129
72
Posted: ‎2020-07-03 01:10 PM . Last Modified: ‎2024-04-08 01:43 AM
635
Hi team!
I recently noticed that my amount of rack unit is not decreasing when I place servers and other components in the rack. I'm running DCO 8.0.4. I noticed that the Rack unit is not decreasing when I place my components on the rear side of the rack. But when I place it on the front side of the rack, the rack unit decreases. I don't know if this is an old and known issue, if it is only on 8.0.4 or if this is due to something that I might have changed in some properties? I've confirmed this issue, where I have a Rack with components only placed on the rear side of the rack, and the amount available is 48 out of 48 possible. The issue is the same no matter if I'm running on Desktop Client or Web Client.
Best regards
Thanh Ly
(CID:111939159)
  • Data Center Operation
Hi Thanh Ly,
This works as designed.
Per design (for all DCO versions), rack physical U capacity information, displayed both via web client and desk-top's "tool tip", is based on the front mounted devices/assets.
Kind regards
(CID:111939184)
Hi Thanh Ly,
Kind regards
(CID:111939184)
Posted: ‎2020-07-03 01:10 PM . Last Modified: ‎2023-10-22 03:43 AM
