How to establish AD authentication in DCO 8.0.3?
  • How to establish AD authentication in DCO 8.0.3?
126
65
Posted: ‎2020-07-03 01:09 PM . Last Modified: ‎2024-04-08 01:43 AM
569
hello,
I have a problem to establish AD authentication in the new version of DCO.
In my old - production version 7.5 it works without any problems. I have such settings:
When I try to apply the same settings to DCO 8.0.3 the AD authentication doesn't work. DCO 8.0.3 settings are shown below:
In both instances of DCO there are remote users defined.
What should I do? Where could be a problem?
BR,
Krzysztof Kęsicki
(CID:111939145)
  • Data Center Operation
Replies 4
569
Hi Krzysztof,
Assuming there is no network related issues between the servers (DCO and AD server), I would suggest trying:
Host: use AD server's IP address (instead host name)
Port: test with port 389 and 636 (use encryption)
Domain: verify that the domain, that is configured on the AD server is correctly typed in.
Kind regards
(CID:112623652)
hi,
thanks for your advice. I have tried with AD IP address instead its name and now it works!! Thank you!!
BR,
Krzysztof
(CID:112626236)
Posted: ‎2020-07-03 01:10 PM . Last Modified: ‎2024-04-08 01:43 AM
Hi Krzysztof,
You are most welcome & many thanks for the update.
Kind regards
(CID:112626244)
Posted: ‎2020-07-03 01:10 PM . Last Modified: ‎2023-10-22 02:30 AM
