Posted: 2024-08-12 09:08 AM
is there a report showing the usage of a PDU from Ecostruxture IT Expert? I see an ups load but I do not see a PDU load.
I am also looking to search all pdu's by model number or Name to get the total power usage from all matching pdu's. I know this is a lot but I just need to see if it is possible or not first
models include APDU10451ME and AP8841
Posted: 2024-08-16 10:53 AM
Hello @rstickland,
As you have seen, there are no reports that exist today for PDUs similar to what exists for UPS Load. You may be able to use sensor plots to graph the sensors in a single view (up to 50) using the compare sensors button in the devices view. You can then add this to a dashboard to easier viewing. This will not give you the % consumed on the device/phase, just the specific value for each of the sensors that you select.
I have submitted a feature request for having a RackPDU Load Report similar to the UPS Load report for you.
From a Dashboard you could create a "calculated" sensor to sum values together within the dashboard widget. When creating the widget you can do some filtering based on Device Type and Models to allow you to more easily filter the the sensors that you desire:
Dashboards only show the value of the sensor. They do not allow you to export the details of the individual components, so you would end up with a single number similar to below:
You can also do graph dashboard widgets with multiple series which would come out similar to this:
Kind Regards,
Cory
Hello @rstickland,
Kind Regards,
Cory
