Posted: 2020-07-05 10:33 PM . Last Modified: 2024-04-03 12:26 AM
I have installed the rack monitor 570 and 4 sensor pod (150) at one of our client site. But there is an issue as i have connect the sensor pod with the rack monitor . It does not show any sensor pod in advance view. Rack Monitor assign the (01 ) number to all sensor pod. Connectivity is fine of all sensor pod with rack monitor.
(CID:149293771)
Dear Shoaib Maqsood,
From your question:
...Rack Monitor assign the (01 ) number to all sensor pod.
This means only one thing - there is no correct connection between the sensor pods, but power is supplied. For more on this, see Steven Marchetti answer from topic :
The 150 uses ID #1 by default. If the device sees another pod in the chain has that ID, it gives it #2 and so on. Subsequently that pod will always have ID #2 until it is added to a chain where #2 (or whichever it was last given) is taken and it will get the next available ID. If it's been attached to a chain, it will retain that ID. There is currently no way to manually alter these IDs...
Please check again:
With respect.
(CID:149293799)
Please tell us, were you able to solve your problem or not?
With respect.
(CID:151062355)
Posted: 2020-07-05 10:33 PM . Last Modified: 2023-10-22 03:42 AM
