Posted: 2020-07-02 01:17 PM . Last Modified: 2024-04-09 04:36 AM
Hi Team,
Customer is going to install DCO on a Red Hat environment and has read the following on our website:
An active RHEL subscription with access to the below channels
RHEL EUS Server Load Balancer channel, RHEL EUS Optional channel
Do they need to have access to these channels even for a single node DCO environment ?
Cees
(CID:97485801)
Hi Cees,
The answer would be yes, I believe the access to the channels is part of the installation requirements.
(CID:97485811)
THX Jef
(CID:97485855)
You are welcome, Cees.
(CID:97485861)
The Server Load Balancer should only be needed for DCO cluster mode. But EUS Optional is required by both standalone and cluster.
(CID:97485870)
THX Mads for the extra information
(CID:97485892)
Hi Mads Mætzke Tandrup I can see the subscription-manager list Which switch do we use to check before we try the install? See 5.1.2 at https://access.redhat.com/documentation/en-US/Red_Hat_Subscription_Management/1/html/RHSM/viewing-no...
(CID:104863397)
I'm not familiar with the UI. Maybe Frank Vissing or Allan Kristensen - Schneider Electric knows.
(CID:105457341)
Hi, You can run subscription-manager repos | grep rhel-6-server-optional-rpms to verify that the proper subscription is active, if not you can enable it using sudo subscription-manager repos --enable rhel-6-server-optional-rpms Hope this answers your question
(CID:105457344)
Posted: 2020-07-02 01:18 PM . Last Modified: 2023-10-31 11:33 PM
