Posted: 2020-07-02 01:37 PM . Last Modified: 2024-04-09 04:29 AM
Imk working with DCO and integrating Panduit preterminated cassettes (Quicknet), but when im trying to connect panels between cabinets, i some panels i have the option "connect to", but in other this option doesn't appears.
(CID:98664486)
Hi Carlos,
just follow the mentioned steps and see the attached screenshots it is very easy to configure.
1st Step:
click on network and network management
2nd Step:
Select your rack where you install the patch panel and click on the patch panel, now you can see the ports in bottom.
3rd Step:
go to the port and right click and click on edit route
4th Step:
now where is other patch panel inside rack or outside rack..? if installed in other rack select the outside of the rack option.
5th step:
after step 4 outside of the rack then the select other rack, then select the 2nd patch panel, then select the require Port. and apply.
Now you can see connected To....
BR,
Rana Ajmal
(CID:99156068)
Hi Carlos,
go to the rack select the Patch panel then click the network and network management option in the bottom then edit the rout.
BR,
Ajmal
(CID:98664489)
Hi Rana,
this is the scenario. i have two cabinets, where we have Panduit High Density Panels (72 LC ports).
i one of the cabinets i have this:
and i would like to connect for example the 24 ports, starting in 49 to another panel outside the rack.
in the other cabinets i have this:
i haven't the option "connect to" i this window. how can i connect those ports?
Regards
Carlos
(CID:98664541)
Hi Carlos,
1st Step:
2nd Step:
3rd Step:
4th Step:
5th step:
BR,
Rana Ajmal
(CID:99156068)
Posted: 2020-07-02 01:37 PM . Last Modified: 2023-10-31 11:31 PM
