Pressure Monitoring
  • Pressure Monitoring
129
72
Posted: ‎2020-07-03 09:41 AM . Last Modified: ‎2024-04-08 03:27 AM
1313
Pressure Monitoring
When will Netbotz (250 - 550 - 570 Series) come with pressure monitoring?
(CID:110013137)
  • NetBotz
1314
Hi Matthew,
we we do not have a pressure monitoring option but we do have 0-5 volt and 4-20 mA options so if you find a 3rd party sensor that uses these protocols, we should be able to monitor them.
Steve.
(CID:110013297)
Replies 7
1315
Hi Matthew,
Steve.
(CID:110013297)
Hi Dear Steve,
I have a netbotz 0451 and a 3rd party 4-20 ma pressure sensor, i connected sensor to the 4-20 ma port on the netbotz, but i couldn't monitor the sensor, and netbotz cant add sensor.
i read help of netbotz, it says i have to add custom , but this item is disable in the netbotz.
could you please help me?
Afsaneh
(CID:112625331)
Hi Afsaneh,
Is it possible that you're logged in as something other than administrator on the NetBotz appliance? I've removed the license I had on my 450 just in case it changed anything and still I am able to add a custom 4-20 mA sensor. On my 450 (same as 451) I am able to:
Select integrated sensor pod:
Select External Ports:
I can see the add custom button:
Choose the 4-20 option:
Configure it (You need to configure yours based on the sensor's manual):
Now I can select that custom sensor as an option:
Steve
(CID:112625747)
Hi Guys,
Thanks for that, and it's awesome to know, also what third party pressure sensor did you use? this is probably the important part for me!
Matt
(CID:116923158)
I use a Netbotz 4-20mA Sensor Pod and pressure transducers to get the signals I want. It isn't as easy and plugging in a temp probe however it isn't too difficult. Wire everything up, configure the pod with the 4 and 20 mA range and vola!
(CID:110013546)
thank you so much.
(CID:112626041)
Posted: ‎2020-07-03 09:42 AM . Last Modified: ‎2023-10-22 03:38 AM
