Posted: 2020-07-02 03:09 PM . Last Modified: 2024-04-09 03:57 AM
Hi!
I have some recommendations for power equipment.
First says "The measured load exceeds the estimated load per phase designed for the rack". What does it mean?
Settings for capacity group:
Second: The breaker configuration in the Power distribution properties does not match the measured power data (1).
I have no idea what it means.
Third: "Breaker configuration does not support rack's estimated load".
There are two 22 kW rPDU in rack, connected to 32A 3P circuit breaker, and tstimated load is 6.9 kW, failover load - 14 kw. Whats wrong?
How to fix that issues?
(CID:100340784)
Hi Valentin,
Please try as suggested here:
The Measured Load of the UPS Exceeds the Total Estimated Load of the Connected Equipment
(CID:100340794)
Hi Valentin,
Please see the following page:
The Measured Load Exceeds the Estimated Load per Phase Designed for the Rack
(CID:100340797)
Thanks Jef! It's a very strange behavior... I remove phase connection and recommendation is gone.
(CID:100340805)
Change from L3 to L1
(CID:100340806)
And what about "The breaker configuration in the Power distribution properties does not match the measured power data"?
I cant find description.
(CID:100340868)
Posted: 2020-07-02 03:10 PM . Last Modified: 2024-04-09 03:57 AM
Hi Valentin, Please see this page: http://dcimsupport.apc.com/display/UAOp74/The+Breaker+Configuration+in+the+Power+Distribution+Proper...
(CID:100340899)
Posted: 2020-07-02 03:10 PM . Last Modified: 2023-10-31 11:30 PM
