Posted: 2020-07-04 02:17 PM . Last Modified: 2024-04-05 02:41 AM
Dear Team,
Kindly, is there any simple third party sensor that detects when power is on or off and can be integrated to the NetBotz appliance.
Felix.
(CID:128757456)
Hi Felix,
There are a few options if the main breaker can take a zero volt contact that will show Normally open when off and normally closed when on you can wire a Dry contact sensor NBES0304 into NetBotz, if the breaker doesn't have this facility you can take a feed from the load side and connect it to a relay that has a coil that can cope with the voltage for site and again wire a Dry contact sensor NBES0304 from the relay into NetBotz.
Hope this helps
Mike
(CID:128757565)
Hi Felix,
Hope this helps
Mike
(CID:128757565)
Posted: 2020-07-04 02:18 PM . Last Modified: 2024-04-05 02:40 AM
Hi Mike,
Thank you for your response.
Can I connect the relay option with normal cat5 cable to the NetBotz NO COM NC ports?
Felix
(CID:128757886)
No Felix, you can not do that.
NO COM NC ports on Netbotz are used to provide relay output from device. But you need to organize relay input, so you need to install relay and connect it's output to Netbotz universal sensor port via DryContact sensor cable. You can extend it with cat5.
(CID:128758023)
Hi Valentin,
Very well noted and thank you for your response. Just that customer needed this urgently and we don't have the dry contact sensor cables.
Felix.
(CID:128758025)
Posted: 2020-07-04 02:18 PM . Last Modified: 2023-10-22 03:36 AM
