Power Mater association
  • EcoStruxure IT forum
  • Power Mater association
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 05:23 PM . Last Modified: ‎2024-04-03 03:23 AM
564
Kindly i have a problem in associating 216 power meters from DCE to DCO, the problem is that i cannot see the names of the power meters in DCO so i can differentiate which power meter shall be associated to which rack.
I have already created a custom property key (Name) in DCE to give names for each power meter, however i cannot see this custom property field (Name) in DCO.
Please see below screen shot:
(CID:140219659)
  • Data Center Operation
Hello Momen.
I do not believe DCE based custom properties are shared with DCO, The data which is typically shared is power (kw and/or amps) and sensor data like temp and humidity. The other based details of the device would be its make/model, name (hostname), ip address and serial number.
Regards
Greg Sterling
(CID:140712738)
Posted: ‎2020-07-05 05:23 PM . Last Modified: ‎2023-10-22 03:36 AM
