Portal will not connect to DCO
  • EcoStruxure IT forum
  • Portal will not connect to DCO
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 04:19 AM . Last Modified: ‎2024-04-05 03:01 AM
743
I am having issues with Portal connecting with DCO. All of my portlet's have been moved permanently somewhere it says. If I try and add a new portlet from DCE I can get data but not from DCO. Did updating to 8.0.01 from 7.5 have something to do with this and how do I get my data back?
Shawn McGowan
(CID:128068543)
  • Data Center Operation
  • Portal
Posted: ‎2020-07-04 04:20 AM . Last Modified: ‎2024-04-05 03:01 AM
Hi Shawn,
I think this connection issue might be because of the need for defining the connection port. In Portal, when connecting to DCO, we can use:
either "http://:8080" or "https://:443"
You might also want to verify if your DCO responding/allowing both http and https connections or perhaps responding only to https.  It can be verified via DCO webmin interface "StruxureWare DC Operation > Setup"
Kind regards
(CID:128068664)
Posted: ‎2020-07-04 04:20 AM . Last Modified: ‎2023-10-22 03:35 AM
