Posted: 2020-07-03 05:17 PM . Last Modified: 2024-04-08 12:15 AM
Good Afternoon
When loading up the Dashboard portal using Google Chrome, the portlets do no load properly, its not the same portlet each time, but there are at least 3 which don't load.
I have loaded the same dashboard in Internet Explorer (v11) and it loads without any issues but the scaling of "CapacityView" I have to zoom out to 68% before i can see the network and U-Space availability. (see Screenshots)
98%
68%
Martin
(CID:120817577)
Hi Martin,
I just tested Portal using Chrome (version 57.0.2987.110 64-bit) without any problem - was wondering perhaps it might be version related (on your side) and might make sense to test it with an upgraded Chrome.But a similar IE (v11) behavior I could also see on my screen (I think this has been a known behavior with IE for a while).
Kind regards
(CID:121211183)
Hi Jef,
Thank you for your reply
I have just tested this with the latest updated version of chrome.
we have 2 separate dashboard views for 2 different Data Centers, one loads fine, second one doesnt show all the portlets, after doing CTRL + F5 it displays fine, however as soon as i close it, then go back to the page, the same portlets fail to load.
Are there any plans for a fix with IE?
Martin
(CID:121211344)
Hi Martin,
Many thanks for your comments - I'm sorry, but as far as I know there are no plans for IE related investigations.
Kind regards
(CID:122094020)
Posted: 2020-07-03 05:18 PM . Last Modified: 2023-10-22 03:35 AM
