Posted: 2020-07-04 03:41 PM . Last Modified: 2024-04-05 12:29 AM
Can I modify the pooling rate for DCE 7.5.0 . The client is monitoring an Symmetra Ups and he wants to know if he could see the input voltage at every second.
(CID:129410955)
Hi Vladimir,
Sorry but no, the minimum polling rate in DCE is 1 minute. If you need to see the ups data at a lower rate, your customer will have to look at the data logs on the device itself.
Steve
(CID:129410960)
Or add a dedicated digital power meter before ups with logging.
If more complex power quality monitoring is needed,consider using PME for more indepth power quality monitoring.
(CID:129410968)
Thank you for your answer! I already propose to the custemer the solution with a power meter.
(CID:129414043)
To clarify:
(CID:129414066)
Posted: 2020-07-04 03:41 PM . Last Modified: 2023-10-22 03:34 AM
