Posted: 2020-07-03 06:25 PM . Last Modified: 2024-04-07 11:52 PM
Hi Team
I have to manage cross-room connexion via 2 patchs panels.
Sample:
Room_1 / Server01 is connected on Room_1/Patch_1 <-> Room_2/Patch_2 is connected on Room2/Server_02
Is like having a cable between Room_1 / Server01 and Room2/Server_02
How can I do that?
Tks for your help
Best Regards
Rocchino
(CID:123340530)
Posted: 2020-07-03 06:26 PM . Last Modified: 2024-04-07 11:52 PM
MANCINO Rocchino
That can be done, by connecting patch panel in room 1's back connection to the patch panel in room 2.
Example done on DCO 8.1:
2 Rooms: DC1 and DC2, a rack with a patch panel and a server:
On DC2's patch panel, on the back connections, select DC1, and the other patch panel.
The 2 patch panels, across rooms, are connected
(CID:123340860)
MANCINO Rocchino
(CID:123340860)
Hello
tks for your answer. I tried this (room1 pp back connection to room2 pp back connection) but when I want to connect my server there is no front port awaible.
I used (GEN_LAYER1_NETWORK_GEAR) with 16 port. Set as 16 back and 16 front....
Tks for you help
Best regards
Rocchino
(CID:123342781)
Hi Rocchino,
Check that both server and patch panel are having the same network connection type.
e.g RJ45 and RJ45?
(CID:123342779)
Hello
Yes!!!!!
It works .
Tks a lot
Have a nyce day
Rocchino
(CID:123342777)
Posted: 2020-07-03 06:26 PM . Last Modified: 2023-10-22 03:32 AM
