Parallel Ups
  • Parallel Ups
128
Posted: ‎2020-07-03 04:17 PM . Last Modified: ‎2024-04-08 12:41 AM
1472
Parallel Ups
Hi
is there any way to model a room with 3 Ups in parallel?
(CID:119048652)
  • Data Center Operation
Replies 9
1471
Does this video cover your setup:
(CID:119048671)
no
is not the customer configuration
3 Ups 400Kw --> power panel --> 2 power panels --> Racks
for now i did this
1 Ups 800Kw --> power panel --> 2 power panels --> Racks
(CID:119048865)
If you simulation 1 UPS 800 kw with internal redundancy, how to show the measured peak load for UPS system?
I mean how to associate the whole 3 ups 400 kw in one modular N+1 UPS 800 kw
(CID:129414524)
Posted: ‎2020-07-03 04:18 PM . Last Modified: ‎2024-04-08 12:41 AM
HI all!
  I checked with DCO demo.
 I associated the 3-4 single ups devises in one modular ups ( for parallel requirement)
  The measured peak load of modular ups will be showed the sum of how measured peak load of individual ups. ( see the bellow pictures)
  Question
  In our DCO got the sensor mapping function for third party floor mount PDUs only, don't have  sensor mapping function for UPS
  Any expert help to explain how should we revised the measured data for third party UPS which was monitored from our DCE?
Regard,
Nguyen Phuc Trang
(CID:130092020)
Posted: ‎2020-07-03 04:18 PM . Last Modified: ‎2024-04-08 12:40 AM
1471
Hi Gianluca
Parallel UPSs are unfortunately not directly supported in Data Center Operations. The suggested work-a-round is to create a single UPS (as you have done) and set the internal redundancy on the UPS to N+1.
Best,
Niels
(CID:119048895)
Hi, I was looking for a way to configure parallel UPS system in DCO couple of days ago. It is a little bit frustrating not to have an option to do it but only a work-a-round
(CID:119049397)
This question has been asked in 2014 here and the same answer "it is being worked on" was given.
I would love to know where on the software feature request list it is (if at all) and why it hasn't been done for over 3 years...
Maybe its just in the too hard basket?
(CID:126158806)
Hello team,  now I have the same situation: 3 x 500KW UPS with an output panel board  and from this one the customer has the distribution PDUs and finally the rack PDUs, all this system is the "A" Feed the "B" Feed is other parallel system... I´m just wondering if the latest version of Struxureware Datacenter Operation can´t manage this situation...
Thanks and best regards,
Erlinson Bravo G.
(CID:126172195)
Posted: ‎2020-07-03 04:18 PM . Last Modified: ‎2023-10-22 03:32 AM
