Posted: 2020-07-05 09:47 PM . Last Modified: 2024-04-03 12:41 AM
Is it possible to configure PUE on a single DCO with Operations & Capacity module for different locations?
If no, can it be done with Colocation module?
Idea is not to use energy efficiency module.
(CID:148342891)
Hi Boris,
Currently in DCO (including Colo) it is not possible to configure PUE for different locations (without EE module). The so-called simple PUE currently may be configured for the whole setup (only one configuration). https://sxwhelpcenter.ecostruxureit.com/display/UADCO8x/Using+the+PUE+DCiE+Dashboard?queryString=PUE
I think possibility to configure PUE for different locations (without EE module) could be a good product feedback and I will share this with our management team, thanks.
Kind regards
(CID:148342912)
Posted: 2020-07-05 09:48 PM . Last Modified: 2024-04-03 12:41 AM
Is there possibility to know how long could it pass before i becomes alive in DCO or IT advisor?
I have a big bid that I am doing & customer want`s 2 DCO systems for 5 locations.
If we get the job it will go in a year or so. DCO has to be on client site, not available sendning data outside company.
(CID:148342959)
Add my voice to this feature, please! 😀
(CID:148343229)
Posted: 2020-07-05 09:48 PM . Last Modified: 2023-10-22 03:31 AM
