Posted: 2022-03-10 07:32 AM
Hello!
USE CASE : Capacity team wants to quickly identify all "Pdu" or "PowerPanel" assets with Power configuration settings. Example below, shows the data we are after…
However, checking the ETL Export database… I cannot locate this data, so I'm pretty sure it's not currently available via ETL processes. Switching to see if this data is exposed via RestAPI. Appears the data can be retrieved but only per asset. (Not in bulk)
Goal is to get the outputVoltage data out in bulk...
Seeking input/guidance on this, Thx!
Posted: 2022-03-14 11:14 AM
Hello Wes, will start a discussion with dev regarding this topic.
I may create one or two feature requests for the capbility if no other options exist today.
Regards
GregS
