OID for Particle and leak rope sensors
  • EcoStruxure IT forum
  • OID for Particle and leak rope sensors
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 12:17 PM . Last Modified: ‎2024-04-09 11:54 PM
769
Hello DCIM Support team,
My customer has a running SNMP manager system , he wants to see the status of the Particle and Leak rope sensors (values too), I explored the netbotz410.mib file but I can´t found the right OID, anyone know where can I get the right OID for this sensors?
Thank you very much for your time.
Best regards,
Erlinson Bravo G.
Cotel S.A. - Colombia
(CID:96044438)
  • NetBotz
769
Hi Erlinson
For a spot leak, you'll want to poll "other state" sensors label first:
.iso.org.dod.internet.private.enterprises.netBotzAPC.netBotz.netBotzSensors.netBotzStateSensors.otherStateSensorTable.otherStateSensorEntry.otherStateSensorLabel
.1.3.6.1.4.1.5528.100.4.2.10.1.4
This will return all state sensors. I suggest naming them uniquely so that you can determine which spot leak is the one you want.
Make note of the instance associated with the label you're looking for. They are long instances and different every time.
In my case, the return for that OID was:
.1.3.6.1.4.1.5528.100.4.2.10.1.4.1266778845
Next, poll the value with:
.iso.org.dod.internet.private.enterprises.netBotzAPC.netBotz.netBotzSensors.netBotzStateSensors.otherStateSensorTable.otherStateSensorEntry.otherStateSensorValueStr
.1.3.6.1.4.1.5528.100.4.2.10.1.7
Match the instance with the one you found under label. IN my case, the one I wanted was:
.1.3.6.1.4.1.5528.100.4.2.10.1.7.1266778845
The value returned in my case was "No Leak"
You could also poll otherStateSensorEntry.otherStateSensorValue
.1.3.6.1.4.1.5528.100.4.2.10.1.2
Which will return a numeric value associated with leak / no leak.
Looking up a particle sensor would be similar. Name the sensors uniquely. Poll them with:
.iso.org.dod.internet.private.enterprises.netBotzAPC.netBotz.netBotzSensors.netBotzNumericSensors.otherNumericSensorTable.otherNumericSensorEntry.otherNumericSensorLabel
.1.3.6.1.4.1.5528.100.4.1.10.1.4
2082493542
Make note of the instance and then poll the value (string, integer, or integer x 1000)
.otherNumericSensorEntry.otherNumericSensorValueStr
otherNumericSensorEntry.otherNumericSensorValueInt
.otherNumericSensorEntry.otherNumericSensorValueIntX1000
Steve
(CID:96044498)
Replies 4
Hi Erlinson, thanks for posting. We will have a look. @community - similar experiences?
(CID:96044461)
770
Hi Erlinson
2082493542
Steve
(CID:96044498)
Posted: ‎2020-07-02 12:18 PM . Last Modified: ‎2024-04-09 11:54 PM
Hello Steve, Thanks for share your experience and commentaries, it will be a great help in this process, I´ll transfer this information to our customer and will post their commentaries here.
Have a great day.
Erlinson Bravo G.
(CID:96045002)
Posted: ‎2020-07-02 12:18 PM . Last Modified: ‎2023-10-31 11:27 PM
