Posted: 2020-07-03 01:47 AM . Last Modified: 2024-04-09 12:29 AM
Dear All,
We have problem with adding PM5320 Energy Analyzer to the DCE which is communicates via Modbus/TCP.
PM5320 Slave address is 255 and I am not able to select 255(max is 252) as a slave ID while adding device on DCE. SC below
Do you have any solution for that ?
Other SC's:
1.
2.
3.
(CID:105470453)
Posted: 2020-07-03 01:48 AM . Last Modified: 2024-04-09 12:29 AM
I have installed DCE 7.3.1, and I am able to see 255 Slave ID selection. Have you tested it with DCE 7.3.1?
regards,
Bala
(CID:105470464)
Hi Balaraman, Thank you, I will try that. Regards,
(CID:105470502)
Hi, How do you have configured the network of PM5320? DCE has detected?.
(CID:105470584)
Im trying to add PM 5320 to DCE but i can´t. Can you help me, How do you configured it?
(CID:105471006)
Hi Miguel angel solans, if you still have this issue I suggest you ask a question of your own. That way you'll get more eyes om it. Best, Stine
(CID:105471007)
Posted: 2020-07-03 01:48 AM . Last Modified: 2024-04-09 12:28 AM
I have one open yet
(CID:105471014)
Posted: 2020-07-03 01:48 AM . Last Modified: 2023-10-31 11:27 PM
