Network Cable Work Order Task - example
  • Network Cable Work Order Task - example
129
72
Posted: ‎2020-07-03 06:05 PM . Last Modified: ‎2024-04-07 11:59 PM
802
 Dear Sirs
How can I integrate the DCO from a template into an EXCEL file to generate the network cabling work order task?
For example of the template:
Kind regards
(CID:122691431)
  • Data Center Operation
Replies 4
802
Hi Marco
Are you trying to get the data into DCO or out of it?
Either way, I don't believe the current DCO API allows access to cable connections so you'll need to use the ETL databases, export or import depending on the answer to my question above.
If you're technically minded, you may like to read all about ETL.  You are going to need some engineering resource, perhaps quite a lot depending on your requirement.
As always, step 1 in my view is to understand what the business is trying to achieve and why.  Then work out how to do and what it'll cost.
Cheers
Ed
(CID:122691473)
Dear ED
I have work requirements to perform based on external data (excel format) and I want to use it to generate work orders in the DCO
Is it possible to do?
Regards
Marco
(CID:122692130)
Hi Marco
Sounds like what you want to do is similar to what the SE team did in Australia for a large bank.  I was involved a little on that project and I think that's might be fastest and least costly way to do what you need.  The lead is Lukasz Staciwo.  He may be able to assist.  Otherwise, I'm happy to discuss further
Cheers
Ed
(CID:122692133)
Posted: ‎2020-07-03 06:05 PM . Last Modified: ‎2023-10-22 03:25 AM
