Posted: 2023-11-01 07:18 AM
We are testing the sending of snmp traps from netbotz (750 and 755) to our NMS.
Both netbotz had the same netbotz50-MIB file under resource page, in the browser UI, and successfully imported one of them into the NMS.
The issue we have is that upon receiving the traps we are unable to convert the OID. I believe this is because the trap is being sent with additional octets at the end of the trap.
For example from a received trap we can see from the field "netBotzTrapErrorType" that a Camera has been unplugged. The trap should therefore have an OID of "1.3.6.1.4.1.52674.500.10.2.2.0.7" (netBotzCameraUnplugged) yet the OID comes in as ".1.3.6.1.4.1.52674.500.10.2.2.0.7.0.62"
Performing a search over all OID's in the MIB does not show this as a valid OID. Why is this being generated and how can we prevent so that the trap is sent with the correct OID?
Posted: 2024-05-06 10:52 AM
Hi @AndrewSL1,
If you still require assistance with your question, I recommend reaching out to technical support for assistance.
Cory
