Netbotz pod sharing
  • EcoStruxure IT forum
  • Netbotz pod sharing
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 02:23 PM . Last Modified: ‎2024-04-09 04:13 AM
372
Netbotz pod sharing
When you pod share multiple Netbotz devices. Should the alert policy be configured on all devices or just the master?
Bruce
(CID:99157463)
  • NetBotz
Hi Bruce,
When using the pod sharing feature, you should be configuring on the "master" device. There are some configurations that require the target device be configured and others that require the "master" to be configured. If you are configuring through the main unit, the configuration window will tell you if this feature needs to be configured on the target device and will forward you over to it as needed.
If you are merely creating thresholds and alert profiles or policies, do this on the main unit. If you do it on the main unit and the target unit, you get 2 alarms. I fboth are set to send e-mails, you will end up with at least 2 e-mails.
Steve
(CID:99157473)
Posted: ‎2020-07-02 02:23 PM . Last Modified: ‎2023-10-31 11:26 PM
