Netbotz Rack Monitor 250 A-Link
  • Netbotz Rack Monitor 250 A-Link
129
72
Posted: ‎2020-07-05 11:55 PM . Last Modified: ‎2024-04-02 11:45 PM
1606
I had a Netbotz 13.56 rack access control in a project and it has 2 A-link port and i have 2 temp/humidity sensors with display can i connect each one on a port or as the manual shows one port should has a terminator while the other can connects to the 2 sensors cascaded ?
(CID:152080479)
  • NetBotz
1607
Dear Islam Fouad Elkholy,
A-Link ports of NetBotz devices are absolutely equal and identical. Therefore, all three connection methods are correct and can be applied:
Term->ALnk|NetBotz|ALnk<---->ALnk|TH1|ALnk<---->ALnk|TH2|ALnk<-Term
Term->ALnk|TH2|ALnk<---->ALnk|NetBotz|ALnk<---->ALnk|TH1|ALnk<-Term
Term->ALnk|TH2|ALnk<---->ALnk|TH1|ALnk<---->ALnk|NetBotz|ALnk<-Term
The basic rule of the A-Link bus, as for similar serial data buses, is the use of terminators (wave impedance balancers of the communication line) at both ends of the communication line.
With respect.
(CID:152080515)
Replies 4
1608
With respect.
(CID:152080515)
Posted: ‎2020-07-05 11:56 PM . Last Modified: ‎2024-04-02 11:45 PM
thank you for you assistance
(CID:152080529)
Ok, very thanks for the good feedback 😀.
(CID:152080531)
Posted: ‎2020-07-05 11:56 PM . Last Modified: ‎2023-10-22 03:23 AM
