Netbotz Cameras Higher Resolution?
  • Netbotz Cameras Higher Resolution?
129
72
Posted: ‎2020-07-03 06:24 AM . Last Modified: ‎2024-04-08 10:48 PM
943
Good day,
I have a Netbotz 570. However I cannot get a higher resolution than 640X480 at 25fps with Normal quality.
The warning message says the following:
Is there a way to bypass this issue?
(CID:108826727)
  • NetBotz
Replies 4
HI! As you can see in Capture Data Summary section, Netbotz can capture images up to 8192 KB size. So, if you want to use higher resolution, you should reduce FPS value, Also you can play with Pre-alert and Post-alert times to reduce capture size.
(CID:108826751)
I concur with Valentin, At your currently listed Resolution and Image Quality settings (image size is 249 KB for each image/Frame) the netbotz is capable of no more than 8192 KB which means your post alert capture time can not be greater than 3.2 seconds which means 3.2 seconds x 10 frames/images is 32 total images at 249 KB which is 249KB x 32 = 7968 KB in total capture...
(CID:108826831)
Thank you very much.
(CID:108826909)
Posted: ‎2020-07-03 06:24 AM . Last Modified: ‎2023-10-31 11:25 PM
