Netbotz 750 sensor showing disconnected
  • Netbotz 750 sensor showing disconnected
126
65
Posted: ‎2020-07-06 01:23 AM . Last Modified: ‎2024-04-02 11:14 PM
2954
I have a Netbotz 750 running firmware 5.2.0. I have 2 x leak ropes and 6 x dry contacts on board with 5 x sensor pods on the A-link bus.
All my sensors are showing disconnected although all sensor pods are on and recording. Any suggestions what the issue could be?
Note that i have a power supply on the one of the sensor pods and have added an additional power supply for testing which has not help one bit.
Kevin
(CID:154796102)
  • NetBotz
Hi Kevin Kolobe,
Had they been working or is this a new install?
What model are the sensor pods, do you have any sensors connected directly and if so are they showing up as disconnected too?
-Gavan
(CID:154796132)
Hi Gavan,
The solution had been running fine and has been deployed for about 2 months now.
All sensor pods are NBPD0155s. 2 of pods have 2 x spot fluids and a door sensor and the rest are only monitoring the room temperature and humidity. On the appliance itself we have 6 x dry contacts and are using both the leak rope ports.
 Kevin
(CID:154796176)
Posted: ‎2020-07-06 01:24 AM . Last Modified: ‎2023-10-22 03:21 AM
